U4GM Pokemon TCG Pocket: How to Dominate with Cyrus
Parduodame čia.
Standartinė Rodrigo60 » 2026 Bir 25 10:50
If you've spent any time with Pokémon TCG Pocket, you'll know the game looks simple on paper. Three points and you're done. But in real matches, that clean little rule gets messy fast. I'd argue that the best way to win more often is to stop thinking only about damage and start thinking about Pokemon TCG Pocket Accounts as well as how many points each KO is really worth. That shift changes everything, because it's not just about taking prizes, it's about making your opponent pay extra for every step forward.
Why point totals matter more than people thinkMost non-ex Pokémon give up 1 point, regular ex Pokémon give up 2, and Mega ex Pokémon can end the game outright when they go down. That means every knockout carries a different kind of pressure. A flimsy Basic that only buys one point is easy to dismiss, but a tanky ex forces your opponent into a much uglier line. They might need one extra attack, one extra turn, or even a whole extra attacker just to keep pace. That is where the real edge lives. You are not only asking, "Can they KO this?" You're asking, "Can they do it without wasting resources?"
Forcing the awkward tradeThe cleanest way to abuse this is to make your opponent overpay. If they have to take your first ex, then another ex, they are now playing a 4-point game instead of a 3-point one. That extra point sounds small, but it often means the difference between finishing with control and scrambling off the top of the deck. Decks built around Suicune ex do this well. You lead with a bulky target, draw a ton, and keep the pressure up while healing or repositioning. Then, when your opponent finally answers it, they still have to keep going. If you can stay efficient while they burn through resources, you've already won the exchange, even before the last knockout lands.
HP can be a hidden form of overkillPeople get stuck on points, but HP does a lot of the same work. If your opponent needs a 200-damage hit to remove a 70 HP Pokémon, most of that damage is wasted. That's not just a number on the card, it's momentum slipping away. A line like Magnezone shows this clearly. It isn't worth a lot in points, but it can soak hits that would flatten other one-point Pokémon. Add in awkward attack math, and suddenly your opponent needs more than one clean answer to finish the job. Oricorio fits this idea too, though in a much meaner way. When the board is thin and your foe only has one real threat left, dropping Oricorio in front can feel like slamming the door shut.
What good players usually rememberThe best decks do not just hit hard. They make the other player work harder than they should. If you're using ex Pokémon, try to push your opponent into a 4-point or even 5-point game. If you're using smaller bodies, make sure they either hit above rate or live long enough to matter. And never leave a stray low-value Pokémon sitting on the Bench unless you really mean to give your opponent an easy way out. Little mistakes like that are how an efficient game turns into a messy one. If you want a smoother climb and a better feel for how these trades play out, it can help to watch stronger lists, test a lot, and even compare notes with players who already have cheap U4GM Pokemon TCG Pocket Accounts ready to go.
Rodrigo60
Užsiregistravo: 2026 Bir 25 06:05
Grįžti į Parduodu
